CME: call-blocking override problem
markus.thelen
Hi all,
I´m using CME 3.1 and want to use "Call-Blocking override": I configured the pattern, the blocking schedule and blocking timeouts under telephony-service and a PIN on the ephone. But it does not work. When I manually switch the clock on the Router, I can reach/not reach the destination. So the dial-peer and call blocking itself work. But override does not :-( What am I doing wrong? I do not have any other files in flash - only IOS. Do I need any other?
Thanks for your help.
5 Replies 5
rnarayana
Level 5
Level 5
Is it a 7* 24 hour block or scheduled block?If the block pattern is 7*24 you cannot override with PIN.
Radhika.
Hi Radhika,
it is a scheduled one...
Markus
Markus,
Can you please copy the configs ?
Radhika
Also what type of phones are you using?
Radhika.
Hi Radhika,
thank you for your ideas. ...I´ve upgraded to 12.3.8T and now everything works fine.
Again, thanks.
Markus
