CME Map incoming FXO calls to a specific DN
stanley-c
Does anyone know if it is possible to map incoming calls on a FXO port using CME loaded on a 1760 router directly to a DN shared by multiple IP phones? I am able to make calls to the FXO port and get the second dial tone to ring the DNs of the IP phones, I would like to eliminate the second dial tone.
rbradfield
Level 2
Level 2
have you tried the PLAR commmand on the fxo port to directly connect to another DN
Thanks for the response. I was using the command plar-opx vice plar, I changed it to plar and the problem is solved.
who knew i could use this after 11 years!!!!
