Codec Pro Downgrade
Currently, have a Codec Pro that is running (ce10.0.1.2.e54a985715f) which happened after a factory reset. I'm assuming this since it original had CE9.14.5.42D28D6C074. Is there any way to roll it back? I've been unsuccessful in doing so.
note: The reason for the factory reset is we run api code to change the system configuration when switching between classification. You must factory rest the system after the code is transmitted to the AMX Master to see if it works. We had were successful on other rooms. However, the room this codec is located is giving us trouble.
16 Replies 16
tell me steps how you did this?
A downgrade uses the same process as if you were preforming an upgrade.
