05-08-2016 04:46 AM - edited 03-15-2019 05:36 AM
Hi All,
I am trying to find a way to configure Cisco IP phones to register with secure-SIP to CUCM and to use SRTP for media traffic. I found only one way to do so, which includes purchasing tokens from Cisco to generate CTL certificate and change the cluster security mode to mixed mode.
like the article below:
https://supportforums.cisco.com/document/73611/ip-phone-security-and-ctl-certificate-trust-list
I was wondering if there is another way to do so, without the tokens, like using a centralized CA server for the new certificates.
Solved! Go to Solution.
05-08-2016 05:18 PM
If you have 10.0(1) or higher, you don't need the tokens. Otherwise you do need them.
Please rate helpful content (i.e. videos, documents, comments). Also, please select the correct answer(s) if any comment(s) answer your question otherwise the questions remains on the support forums as unanswered
05-08-2016 03:08 PM
What version of CUCM?
05-08-2016 05:18 PM
05-18-2016 06:09 AM
thank you for your answer.I am testing it in my lab setup currently. I will post the results once done the testing.
