02-23-2006 02:05 AM - edited 03-15-2019 04:06 AM
I have problem about connection between VT Advance and PC.
icon tray displayed the exclamation mark. i think this mark meaning connection problem between VT Advance and PC, that is, not sync both of them.
How can i troubleshoot this issue?
Regard,
John.
02-23-2006 09:27 AM
John,
Open VT advantage and you should see two links.
a. between phone and PC
b. between camera and PC
Both should be green for VT to work. If you see a mark sign it could mean either one of the links or both are down.
I would check if the camera is showing up on your PC as working properly (just to make sure drivers have been installed properly when you installed VT advantage on this PC)
I would also check if the phone has Video capabilities enabled. You need to do this on the phone configuration page (under device, not line)
By default this feature is disabled.
I would also check if you are using the right CM version 4.x, with the appropriate phone load for a 7960/40 that supports video capabilities. (this is applicable only if you are using a 7960/40)
Sankar
PS: please remember to rate posts!
02-24-2006 12:17 AM
Hello Sankar,
Thank you for your advise.
It's ok between PC and CVTA, but not ok between PC and IP Phone. I can see a mark sign between PC and IP Phone.
I tried to test with ping from PC to IP Phone, but There is no issue. Additionally, I already configure "video capability" option on CCM for IP Phone.
How do you think about this?
John.
