CUE - After greeting -no beep sound
lleweyiss
Level 4
Level 4
CUE  Version 8.6.6 -  after a greeting there is no beep sound to indicate to callers to begin leaving a message.
Never seen this before,  any ideas for things for me to check ?
New CUE, only had it for approximately 3 months.
Murali Gunnam
This is weird issue, I would like to check the following things -
++ Is the issue happening for every extension ?
++ What happens when you keep the call active after greeting ?
++ Have you tried reloading the CUE ?
++ Please share the CME config
Krish
Just FYI ... opened TAC case  as this was happening to all users on this CUE.   TAC said I needed to upgrade to 8.6.11   .
Had other locations with the same CUE version 8.6.6 without the issue, but TAC said it was the solution to my issue.
