Deploying Multiple CMS Web Bridges and Load Balancers
Joey De Wiele
When deploying multiple web bridges Cisco recommends three methods of preventing calls from dropping if WebRTC clients rehome to different web bridges:
  • Deploy Expressway for external access and use the Expressway CMS WebRTC proxy to load balance across the Web Bridges.
  • Use either GeoDNS or IP address hashing to select the IP address the DNS will return.
  • Use the CMS Load Balancer component. But with this solution, you then have the problem of deploying multiple Load Balancers.
I understand the concept of IP address hashing to ensure that the same CMS server address is always returned but I can't find any information on how to configure this. Is this a feature a Microsoft DNS server can provide or is it something that a public DNS service provider would offer?
Do you use the same process to allow clients to discover multiple load balancers as you would to deploy multiple web bridges?
Joey
0 Replies 0
