02-24-2005 07:50 PM - edited 03-13-2019 08:08 AM
Dialing 1XXX XXX XXXX fails with busy tone.
Local 7 digit works fine.
Have route pattern
1. 9.@ with filter area code does not exist
DDi predot
2. 9.1[2-9]XX[2-9]XXXXXX with filter.
area code exists
DDI predot
Running Callmanager 4.1.2 MGCP gateway to 1760 with 2port FXO.
Anyone know why I am getting a busy tone on long distance calls?
02-24-2005 08:06 PM
What is the cause code in the disconnect message? Cna you post the Q.931 for the call, from the CCM traces?
Mike
02-24-2005 08:44 PM
Also Route-Filters only work with the @ symbol like 9.@ or 9@. I would use DNA to see which pattern it is hitting.
Also are you stripping the digit in the route pattern or in the route-list? I have seen it give a reorder tone if stripping it on the RL and if you put it in the route pattern it works fine.
02-25-2005 06:30 AM
Which trace do I enable? Do you want detail or error?
This is a regular analog POTS line I am dialing out on.
02-25-2005 10:14 AM
This is weird. When I make an 11-digit call this error populates the windows event log in the callmanager. Looks like the gateway unregisters.
Eventid:3
Source:CiscoCallManager
Error: DeviceUnregistered - Device unregistered.
Device name.: AALN/S0/SU0/0@CMEROUTER.bergmantech.com
Device IP address.: 10.90.124.10
Device type. [Optional]: 121
Device description [Optional].: AALN/S0/SU0/0@CMEROUTER.bergmantech.com
Reason Code [Optional].: 9
App ID: Cisco CallManager
Cluster ID: CISCOCM-Cluster
Node ID: CISCOCM
Explanation: A device that has previously registered with Cisco CallManager has unregistered. This event may be issued as part of normal unregistration event or due to some other reason such as loss of keepalives.
Recommended Action: No action is required if unregistration of this device was expected..
Why would this happen and only on long distance calls?
02-25-2005 10:21 AM
Debug MGCP events and errors on Gateway display.
CMEROUTER#
.Feb 25 18:12:15.123: mgcp_endpt_get_call_record: null pointer specified for end
point.
.Feb 25 18:12:15.139: mgcp_call_set_error_state: callp(0x81CA5A18)
.Feb 25 18:12:15.139: -Traceback= 81606BD4 816488B8 8160A614 8160A53C 8167FF90 8
162401C 81623F30 815FD648 8021AEF8 8021F510
.Feb 25 18:12:15.139: mgcp_endpt_get_call_record: null pointer specified for end
point.
.Feb 25 18:12:15.147: mgcp_search_trans_id_rec: trans id not found. rc = 3.
02-25-2005 12:04 PM
Can you set the CCM traces to detailed on the CCM the GW & the phone are registred to?
MIke
02-26-2005 07:27 AM
Attached is a trace with CCM All Gateway, Phone, and analog trunk set to detailed. I have so far deleted all route patterns, gateways, and upgraded IOS code on router to 123-8.T6. Wiped the router config and reprogramed the Callmanager and router.
Also, the voice gateway 1760 router config is attached.
Changed route patterns to:
9.[2-9]XXXXXX local 7 digit predot
9.1[2-9]XX[2-9]XXXXXX longdistance 11 digit predot
Local calls work fine.
Longdistance causes the gateway to imediately unregister from call manager. I can't figure it out. It makes no sense. The windows event in the previous reply takes place right after the call gets routed to the gateway.
Thank you all for helping me out.
02-26-2005 10:29 AM
02-26-2005 08:36 PM
The router cfg looks good, and IOS is newer (12.3(8)T6) but the traceback message is indicator of bug/IOS issue usually.
And port 0/0 has pulse dialing; I haven't seen pulse used in awhile myself and not w/voip yet. The other port isn't pulse dialing. Is this the way it really is? Maybe there is something going on here funky.
Can you dial 11 digits out the 0/1 voice-port without issue or do 11 digits out either port cause mgcp reset?
You can try going in route detail/group in CCM and flipping order of ports if they are in same group or just removing 0/0 from the list for a test.
02-27-2005 08:53 AM
This is a using a residential POTS line with pulse dialing. Only 1 line in use in port 0/0. I can test on port 0/1. Currently only port0/0 is in the route group.
So wierd that 7 digit dialing works fine. But 11 digit doesn't. Long distance works fine with analog phone so its not the phone company.
I used to have CCME 3.2 on this router and it dialed fine for long distance. It has to be something with MGCP and Callmanager 4.1.2.
02-27-2005 01:45 PM
Does that traceback message occur everytime you try a 11 digit dial and MGCP resets?
Can you post a 'show stack' and a 'show align' from this router?
02-27-2005 03:21 PM
I do not know if I get a traceback message but I can tell you that every 11 digit dial causes an MGCP reset.
Here are the show commands you requested. Should I try a different version of IOS?
voicegw#show stack
Minimum process stacks:
Free/Size Name
5608/6000 Clock Update Proc
2724/3000 allegro libretto init
5696/6000 CPE MMI SNMP
5796/12000 Init
5576/6000 RADIUS INITCONFIG
2568/3000 Rom Random Update Process
4920/6000 TFTP Read Process
6656/12000 Exec
35284/36000 TCP Command
6656/12000 Virtual Exec
6064/12000 MGCP Application
5128/6000 MGCP App STW Tick
5672/6000 MGCP App DNS
11672/12000 MGCP App TFTP
Interrupt level stacks:
Level Called Unused/Size Name
3 0 9000/9000 PA Management Int Handler
4 5716805 7944/9000 Network interfaces
5 0 9000/9000 Timebase Reference Interrupt
6 591757 8880/9000 16552 Con/Aux Interrupt
7 40224998 8920/9000 MPC860 TIMER INTERRUPT
voicegw#show align
No spurious memory references have been recorded.
02-27-2005 03:42 PM
02-27-2005 06:38 PM
I am not finding any specific bugs in bug toolkit or release notes from newer versions. It won't hurt if you want to try upgrading though to latest 12.3T.
Most residental lines these days are tone and not pulse dialing. I can't find reference to pulse dialing being supported or not supported with MGCP. It is not a option in the CCM web page gateway configuration pages though.
You could also configure the gateway as a H323 gateway and see how that goes.
Since this worked with CME, and MGCP resets everytime with a 11 digit call it smells like a MGCP bug/issue.
I have plenty of customers with 1760s and FXO and MGCP and haven't seen this type of problem yet, but this is also the first I've seen pulse dialing used w/MGCP so that may be a factor.
