09-26-2005 07:04 AM - edited 03-15-2019 03:43 AM
we are setting up a test lab of termination in cisco as5300 using R2 signaling in POTS line. However I have problems that everytime we terminate the calls stripping the number countrycode and areacode..and call only the telephone number, I have a disconnect cause code 19 thus the caller did not accept the call or nobody answer. This is strange because I am calling my office desk telephone number.
See below my config for your reference.
dial-peer voice 19 voip
destination-pattern 632T
session target ras
dtmf-relay cisco-rtp
dial-peer voice 101 pots
direct-inward-dial
port 0:0
prefix ,,
Do you have thoughts, or there is lacking or something to modify in my configuration.
Advise.
09-26-2005 07:22 AM
Hi John - can you give us a snapshot of your "debug isdn q931"? What number are you dialling - it's unusual that your voip and pots destination patterns are the same, but I don't know what you're trying to dial.
09-26-2005 07:30 AM
I cant find the command "debug isdn q931" in my gateway. Please be informed that am using R2. What is the equivalent debug commands of "isdn q931" in r2?
I am calling 006328331234 strip 00632, and the voice will call only the local number 8331234.
09-26-2005 08:00 AM
Router#
Q931 Message IE Decodes
Protocol Discriminator : 0x08
CRV Length : 2
CRV Value : 0x1271
Message Type : 0x05: SETUP
Bearer Capability: Length Of IE=3
Data 8090A2
Called Party Number: Length Of IE=12
Data 913936363338333339313538
User-User: Length Of IE=330
Data 0530B0060008914A0003020680344B975695AB6A400600640061006D006D0061006D003228C0B50007273F54656E6F7220416E616C6F672041
383030204D756C74697061746820537769746368202D203820706F72747320285265762E2042290000923DF800475B4C00001F50342D322D32302D33
38284C4543292028313733333138352F3078383143352900020500C996B66C48B4090063006900730063006F005F0076006D0067006B003432356466
6430393261663000320000007D1D980700D464D41E06B91100343235646664316132616632003200003402130024CE0D000040000A04000100D464D4
5328011E4024CF060401004D000040001114000100D464D453280000D464D453280101000100010001000100010040B5000727250C0103180228000B
043632373705010008063936363333330F0B413030322D30303333333308800180
CRV Length : 2
CRV Value : 0x9271
Message Type : 0x02: CALL_PROC
User-User: Length Of IE=117
Data 052180060008914A00042800B500001240023C0501002C0501000447001100343235646664316132616632003200003D021B0024CE0D000040
001215000100D464D4564AAC00D464D4564AAD001F400000060401004D000040001215000100D464D453280000D464D4564AAD000100010010800180
CRV Length : 2
CRV Value : 0x9271
Message Type : 0x01: ALERTING
Progress Ind: Length Of IE=2
Data 8088
Signal: Length Of IE=1
Data 01
User-User: Length Of IE=55
Data 052380060008914A00042800B500001240023C0501002C05010006C3001100343235646664316132616632003200000100010010800180
CRV Length : 2
CRV Value : 0x9271
Message Type : 0x5A: RELEASE_COMP
Cause: Length Of IE=2
Data 8093
User-User: Length Of IE=34
Data 052580060008914A0004110011003432356466643161326166320032000010800180
