DMM - DMP connectivity over DSL network
sukitti.l
Dear All,
I would like to know whether it is possible to connect DMM - DMP over DSL Network.
-     I have DMM with private IP 192.168.1.100 have static net public IP 58.177.200.xx
-     I have DMP with private IP 192.168.xx.xx connect under ADSL network with Dynamic IP address.
I check NAT enable on DMPDM but It ask me to enter ADSL public IP. When DSL line down and reconnect IP is change.
What Should I do?
Thank you very much
Sukitti
Daniel Arrondo Ostiz
Hi Sukitti,
I'm afraid this will never work. As you already saw, you can use the DMP with NAT, but the public IP needs to be fixed.
Your best approach would be to contact your ADSL service provider and request a fixed IP for that connection. Most of providers give this option for a small extra amount
Daniel
