EX90 default auto light setting to low...can I tweak it somewhere?
aalbrechttpn
I proudly own a EX90 Video station. Love it with one exception. When I set the camera to automatically adjust to the light conditions..it works as it adjusts,but it always remains too dark. So I end up...sitting at a windows...adjusting manually the lighting up and down during a call..
I would assume that the EX90 stores a default value for automated adjustment....is that setting adjustable anywhere? So that it does function automatically but at a slightly higher light level?
Kind regards Axel
Patrick Sparkman
The only options that might suite your needs is manually setting the brightness and whitebalance levels, however this will disable the automatic adjustment modes of each if manually set.
Cameras Camera [1] Brightness Level
Cameras Camera [1] Whitebalance Level
See the "Cameras" section in the EX Series Admin Guide starting on pg 62 for more information on these settings and other camera options.
