failed call through H323 gateway and CUCM 8
NONA_1986
i have a 3845 gateway added as h323 gateway on CUCM 8.
we i try to make an outbound call .
The system cannot complete the call.
"Your call cannot be completed as dialed Please  consult your directory and call again or ask your operator for assistance "
when i opend a debug h245 on the GW  i get the below output .
023334: *Apr 12 13:08:55.918: %C3800_ENVM-3-MFAIL_OFF: There is more than one fa
ilure with the Power System 2 or this Power System has been turned off.
023335: *Apr 12 13:09:15.918: %C3800_ENVM-3-MFAIL_OFF: There is more than one fa
023336: *Apr 12 13:09:33.906: h323chan_chn_process_read_socket: fd=0 of type LIS
TENING has data
023337: *Apr 12 13:09:33.906: Changing to new event: ACCEPT
h323chan_chn_accept: fd=0
023338: *Apr 12 13:09:33.906: h323chan_gw_accept: TCP connection accepted from 1
72.19.0.141:40444 on fd=2
023339: *Apr 12 13:09:33.906: h323chan_chn_accept: Local(0x0) accepts TCP conn f
rom 172.19.0.141(0xAC13008D) port (40444); fd=2changing from LISTENING state to
ACCEPTED state
023340: *Apr 12 13:09:33.926: h323chan_chn_process_read_socket: fd=2 of type ACC
EPTED has data
023341: *Apr 12 13:09:33.930: h323chan_close: TCP connection from fd=2 closed
023342: *Apr 12 13:09:35.918: %C3800_ENVM-3-MFAIL_OFF: There is more than one fa
can  any one help ??
Then look at your H323 config and make sure you're matching a destination pattern on a DP and the DP is up.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
Start by checking CSS/partitions on CUCM, then make sure you're matching a dial-peer on H323 and that the target (VOIP or POTS) is up
java
java
i think it is a Gateway issue not a CUCM issue .
i have check the CUCM by using DNA and here is the result .
  9701005041942
  RouteThisPattern
  01005041942
  192.168.10.200
  OnNet
  NO
  Disabled
  NO
  01005041942
  1105
  NO
  1105
  01005041942
  Yes
  18
  No
  1105
  9701005041942
  NO
  Default
  Default
  1105
  Default
  Default
  PreDot
  01005041942
  192.168.10.200
  UnKnown
  Disabled
  Disabled
  Use System Default
  None
  1105
  Originator
  Default
  1105
  97.01[^3]XXXXXXXX
  Enterprise
  OffNet
  AccessDevice
  ExecutiveOverride
  RouteClassDefault
java
java
solved after adding the right destination pattern at the pots DP .
Thanks alot
