Fax over IP Problem
goku-sun
Hi all,
I have been looking into a problem that 2 remote sites are connected by cisco 1750s where one of the voice ports is connected to a fax machine at each site. Without packet loss and bandwidth consumption problems(256K line, only 1 fax + 1 voice & few data traffic), I cannot solve:
1) The faxing speed is slow.
2) Very often the faxing process stops in the middle.
3) Very often the fax output becomes distorted..
4) Poor voice quality
Is there anything I can improve the fax operation between the 2 sites with router comamnds together with fax process?
Have you guys exprienced these before and have some hints to me?
A truncated config(both sites are similar) is as follows:
nterface Serial0
bandwidth 256
ip unnumbered FastEthernet0
ip nat outside
encapsulation ppp
ip tcp header-compression iphc-format
no ip mroute-cache
load-interval 30
priority-group 1
ip rtp header-compression iphc-format
ip rsvp bandwidth 96 24
dial-peer voice 20 voip
destination-pattern 2050
session target ipv4:1.2.3.4
req-qos controlled-load
fax rate 9600
ip precedence 5
Thanks in advance,
Goku
MARTIN STREULE
During the call, if you type "show voice dsp" - what do you read in the row "codec"? (does it mention "fax", "9600" or "g.711u"?)
If you don't read fax or 9600 you don't use fax-relay. Without fax-relay I had problems with the same symptoms too.
Be sure you use an IOS which supports fax-relay.
With fax-relay I had no problems with 14'400 fax with the g.711 codec.
I also had to enter "incoming called-number xxxx" in both dial-peers.
Martin
Many thanks Martin,
Just want to confirm to enable fax-relay, does it mean disabling ECM by command "fax-relay ecm disable" under the dial-peers? And it will consume much more BW if using codec g711?
Cheers,
Goku
you need the command
fax protocol t38 ls-redundancy 0 hs-redundancy 0
on the dial-peers. The ECM, as far as I know, should be disabled, since not all fax machines support it.
