12-22-2005 07:33 AM - edited 03-13-2019 11:39 AM
Hi, Im having problems sending fax on a e1 mgcp configured, I tried sending the fax over an fxo and Works fine. The problem is that I get unstable fax.
I tried configuring fax relay t38 and fax pass-through and I get the same result.
The e1 and fxo are located on a MGCP gateway 3825 and the fax is connected via VG224 also configured in MGCP to an cm 4.1.3
12-22-2005 09:29 AM
At the beggining check if your E1 controller is free of errors.
regards
Wojtek
12-22-2005 09:42 AM
Wojtek, I have some slip secs and error secs. In the guide above it says it's sensitive to that, so i will talk to the pstn provider for that.
Thanks! I tell you later.
Carlos
12-25-2005 04:49 AM
Hi Carlos,
Make sure you have the network-clock-select command configured for the E1/T1 controller.
If you dont there will more than likely be slip errors when doing show controller
Allan
Allan
