Forward calls not in Missed Calls.
lhelsen
On a Cisco 7940 & 7960, when you receive a forwarded call you see from where the call is forwarded and you see the original caller his number.
When you do not answer this forwarded call, and after a while you take a look in the Missed Calls Directory, you only see the number who has forwarded the Call.
Does someone know a way to find out the caller his number in this directory?
lkneschke
I'm using CM 3.2 and i see the number of the external user.
1.) forwarded all calls from 60 to 61
2.) call number 60
3.) number 61 is ringing
4.) in missed calls on number 61 i see the external number
