FXO problem
mohammedmahmoud
Level 11
Level 11
Dear all,
i've configured my FXO as following and i got this error when debuging (it some times works and some time doesn't work):
fb_get_reject_cause_code: ERROR cause_code NULL
voice-port 2/0
dial-type pulse
dial-peer voice 4 pots
description Dial Peer to Mobile phones ("8" + 10 digits)
destination-pattern 9...........
port 2/0
forward-digits 11
Thanks in advance.
smahbub
Level 6
Level 6
I suspect that you are running into a bug here. The bug-Id is: CSCee10512
hi,
is it possible to get the following information-
1. does this happen to both inbound and outbound ?
2. deb voice ccapi inout
3. deb vpm sig
4. deb vtsp all
a small call flow would be great.
thanks,
subhrojyoti
