FXS MGCP Problem.
mferhai
I have a problem on the FXS Port (EM-HDA4FXS)configured on the cisco3660 with ios 21.3(7)T and CCM version 3.2SPH.
Each time the FXS port stops to work and i need to restart the voice port and dial-peer with shutdown and noshutdown commmand.
When the FXS stops responding (not reachable) and when i type the show voice port x/0/x i get
- Operation State is UP
- Administrative State is UP
It seems that the problem is that the voice port doesn't disconnect.
I was trying some IOS without success,
any solution to fix definitively the Problem?
See my attached file (Configuration of the FXS MGCP)
Not applicable
Hi, there
Can you try debug and paste a complete call message flow?
joshw
Did you ever find the fix for this? I have this happening with 26XX routers as well. A shut / no shut seems to bring it back to life.
