01-10-2008 03:49 AM - edited 03-15-2019 04:58 AM
Could anyone give me some pointers on how to obtain CDR's using AXL on Call Manager 5 or 6? What AXL calls do I have to make for example? Is this possible?
01-10-2008 04:40 AM
I don't know how or if it is possible. But why don't you configure the Call Manager to push the cdr files to a ftp folder.
Then you can do what ever you want with those cdr files.
1. Login on the Call Manager admin page
2. Select 'Cisco Unified-services' on the most top-left corner.
3. Select 'Tools' -> 'CDR Management'
There you can add a new server / ftp folder to send cdr files to.
01-10-2008 05:10 AM
01-11-2008 04:28 AM
This looks good although i am having problems when i execute the AXL. The error i am getting is as follows:
ERROR: No Handler found for in0
5003
01-11-2008 05:21 AM
Send your request if you want some help
01-11-2008 05:30 AM
My error is slightly different but still the same ....
Request:
Response:
ERROR: No Handler found for multiRef
5003
01-14-2008 05:58 AM
Does anyone know of an application, which will allow me to test my AXL against call manager 6? There is an AXL SQL toolkit supplied but this only works with SQL statements. I have attempted to create a Java application, which can achieve this, but this may be what is causing the errors. The existing AXL testing application source code on the Cisco site does not take into account that Call Manager 6 requires an SSL connection.
01-24-2008 08:04 AM
