Hard code speed and duplex on phone
kdamisch
Any way to remotely change the speed and duplex of an IP Phone? Manually changing it on each phone is quite time consuming.
Kevin
Aaron Harrison
Search this doc for the word 'duplex' - basically if you set it on the phone then you need to set it on the PC and the switch or you will have a duplex mismatch... so you'll have some legwork to do either way...
Why would you want to do it anyway?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
