Have some voice problem and need some advice
ho.peter
I have some problem at my voice network. I connect two 1750 with FXO and FXS at 64K Lease line. But there is some voice delay, echo and can¡¦t dial to branch side usually. I had done some QoS on it. Anyone can give me some advice? I attach the router config for reference.
Head Office router: (4 voice FXO interfaces)
Building configuration...
Current configuration:
version 12.1
class-map voice
match access-group 100
policy-map llq
class voice
priority 45
memory-size iomem 25
ip subnet-zero
no ip finger
no ip domain-lookup
voice-port 1/0
input gain 6
output attenuation 12
echo-cancel coverage 32
connection plar 8601
description connected to PABX no.082
voice-port 1/1
input gain 6
connection plar 8602
description connected to PABX no.084
voice-port 2/0
input gain 6
connection plar 8603
description connected to PABX no.081
voice-port 2/1
input gain 6
connection plar 8604
description connected to PABX no.035
dial-peer voice 85201 pots
destination-pattern 85201
port 1/0
dial-peer voice 85202 pots
destination-pattern 85202
port 1/1
dial-peer voice 85203 pots
destination-pattern 85203
port 2/0
dial-peer voice 85204 pots
destination-pattern 85204
port 2/1
dial-peer voice 8601 voip
destination-pattern 8601
ip precedence 5
session target ipv4:210.254.255.2
dial-peer voice 8602 voip
destination-pattern 8602
ip precedence 5
dial-peer voice 8603 voip
destination-pattern 8603
ip precedence 5
dial-peer voice 8604 voip
destination-pattern 8604
ip precedence 5
interface Tunnel0
bandwidth 64
ip address 192.168.254.1 255.255.255.252
tunnel source 210.255.10.2
tunnel destination 210.254.255.2
interface Serial0
mtu 300
bandwidth 64
no ip address
encapsulation frame-relay
no ip mroute-cache
service-policy output llq
frame-relay lmi-type ansi
frame-relay ip tcp header-compression
frame-relay ip rtp header-compression
interface Serial0.133 point-to-point
bandwidth 64
ip address 210.255.10.2 255.255.255.252
no ip mroute-cache
frame-relay interface-dlci 133
interface FastEthernet0
ip address 192.168.1.253 255.255.255.0
speed 10
half-duplex
ip classless
ip route 210.254.0.0 255.255.255.0 Tunnel0
ip route 210.254.255.2 255.255.255.255 Serial0.133
ip route 192.168.19.0 255.255.255.0 Serial0.133
ip route 211.159.29.17 255.255.255.255 Serial0.133
no ip http server
no scheduler allocate
end
Branch Office router (4 voice FXS interfaces):
version 12.1
memory-size iomem 15
ip subnet-zero
voice-port 1/0
input gain 4
output attenuation 6
description connected to ext.007
voice-port 1/1
input gain 4
description connected to ext.008
voice-port 2/0
input gain 4
description connected to ext.005
voice-port 2/1
input gain 4
description connected to ext.006
dial-peer voice 8601 pots
port 1/0
dial-peer voice 8602 pots
port 1/1
dial-peer voice 8603 pots
port 2/0
dial-peer voice 8604 pots
port 2/1
dial-peer voice 85201 voip
ip precedence 5
session target ipv4:210.255.10.2
dial-peer voice 85202 voip
ip precedence 5
dial-peer voice 85203 voip
ip precedence 5
dial-peer voice 85204 voip
ip precedence 5
interface Tunnel0
bandwidth 64
ip address 192.168.254.2 255.255.255.252
tunnel source 210.254.255.2
tunnel destination 210.255.10.2
interface Serial0
mtu 300
ip address 210.254.255.2 255.255.255.252
no ip mroute-cache
traffic-shape rate 64000 1000 0 1000
ip rtp priority 16384 16383 45
ip address 210.254.0.1 255.255.255.0
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 10.254.255.1
ip route 210.254.0.0 255.255.255.0 Null0
ip route 192.168.1.0 255.255.255.0 Tunnel0
no ip http server
end
Chester Rieman
FRF 12 support 2600 or 3600 series. How about this case which is 1750?
newtona
Try taking off header compression and also check what codec you are using. if you are using G711 on a 64k line then that would add some delay as it uses around 88k, try using G729a.
