04-08-2013 03:12 PM - edited 03-13-2019 08:11 PM
Hi experts
i have a project and i need help from all of you , to do a design and a perfect implementation.
Solved! Go to Solution.
04-08-2013 03:18 PM
Dear
You are very welcome , kindly send to me your requirements.
Thank you
04-17-2013 06:12 PM
Hello
For conversion for your video library , ok you can do it by the below
1- You can use Cisco converter (like AS5510 or 7710) for convert from digital to IP or you can a specific tools for Video conversion from analogue to digital by studio or some thing like that , pleae identify your resources.
2- Your design will be ( live cam - enconder - WOWZA server or adobe flash server - ECDS -DMP).
3- IPTV (Headend -DCM9900 like encoder alseo- Multicast network - DMP) .
Thank you
please rate if this will help
04-22-2013 10:42 PM
Hello
Hello
ECDS , is a system which consists of service routers , service engines ,etc . When user sends a request for video the service router will be responsibe with integration (DNS) will hendle the requests from user after that will send these requests to service engines and so on , for more details . Please find the below links which will help
http://www.cisco.com/en/US/products/ps11281/Products_Sub_Category_Home.html
Thank you
04-22-2013 10:45 PM
Hello
Kindly find the below
http://www.cisco.com/en/US/prod/collateral/video/ps9901/ps10631/q_a_c67-565668.pdf
http://www.cisco.com/en/US/prod/collateral/video/ps9901/ps10588/ps10630/guide_c45-687395.pdf
Thank you
Islam Kamal
04-25-2013 04:55 PM
hello
http://www.cisco.com/en/US/prod/collateral/video/ps9159/ps9195/ps9230/7004373.pdf
http://www.cisco.com/en/US/netsol/ns723/networking_solutions_solution.html#~prod_services
Thank you
04-25-2013 05:00 PM
hello
For IPTV , IPTV multicast based . Your solution will based on end to end as below
1- DCM which will act as encoders.
2- for HD or SD you will use other encoders ( AS 5510 , As 7710)
3- You have to enable Multicast .
4-Use DMP or STB to receive channels.
Thank you please rate if this will help
04-25-2013 05:04 PM
hello
redundancy is so important , because if for example DMM is failure for SNS (SNS will be down ) , You have to use redundancy to avoid failure.
Thank you
04-25-2013 05:04 PM
Hello
use the below link for DCM IPTV
http://www.cisco.com/assets/global/YU/expo2012/pdfs/d9036_deep_dive.pdf
Thank you
04-25-2013 05:06 PM
Hello
use the beloe link for SNS and DMS design
http://www.cisco.com/en/US/docs/solutions/Enterprise/Video/DMS_DG/DMS_dg.html
thank you
04-26-2013 10:47 PM
Normally the most popular mode that's used in multicast is 'sparse mode' It is used because its far more efficient than dense mode and sparse-dense mode.
But for sparse mode you need a rendezvous point. All your multicast traffic will be pulled instead of pushed.
I'm not sure how the multicast is set up on IPTV, do you normally specify the multicast group address and the RP?
This also means you need to set 'ip pim sparse-mode' command under every single interface on the routers in your network, even vlan interfaces that the multicast traffic needs to traverse.
And you will also need to define 'ip pim RP-address x.x.x.x' on all your routed hops (your routers)
All your switches will need to support IGMP, if they are Cisco switches, it is enabled by default.
If its your first time with multicast, and you want to know a bit more about it, go to YouTube
http://www.youtube.com/watch?v=AvbSMBKBZgY
Or
http://stormwind.com/category/multicast
And watch the episodes. It's very good for beginners and it helped me a lot!!
It's funny because I'm also working on IPTV solution too :-)
Hope this helps
04-27-2013 05:13 AM
Hello
very helpfull , we need your help mr/bilal as you one of the expert for routing . Kindly be informed for me we use SSM multicast , for multicast implementation please answer the below questions:-
1- Do you have a WAN connection?.
2- Do you have mpls between your sites?.
Thank you
04-27-2013 05:14 AM
Hello
if you have a MPLS connection , kindly be informed your configuration will be as the below
1- Multicast over MPLs.
2- Enable multicast for your switches which will connect to your switches.
For SSM multicast :
P2MP = SSM trees
Build trees from any individual source.
Inject everywhere, receive everywhere
-Best join/prune latencies
Q. What is Source Specific Multicast?
A. Source Specific Multicast (SSM) is an extension of IP multicast where datagram traffic is forwarded to receivers from only those multicast sources to which the receivers have explicitly joined. For multicast groups configured for SSM, only source-specific multicast distribution trees (no shared trees) are created.
Q. Should I use PIM Sparse-Mode or Dense-Mode?
A. Cisco recommends PIM Sparse-Mode (PIM-SM). Cisco also recommends PIM-SSM for one-to-many applications and Bidirectional PIM (bidir-PIM) for many-to-many applications.
Thank you
04-27-2013 05:15 AM
hello
Kindly find the below links which will help
ftp://152.33.34.12/CiscoLive/VVT/BRKVVT-2102.pdf
https://supportforums.cisco.com/thread/2097878
Thank you
04-27-2013 09:52 AM
hi bilal
i need your help to help jack for his design and i need your suggestions as you one of expert in routing.In your case it is so easy as you mentioned above you will use sparse mode and enable ip multicast routing on your switches and enable IGMP.
Thank you
04-27-2013 11:27 AM
Hi jack
please share with us your topolgy ,your WAN connection , number of sites , locations of your end points which will join multicast ?.
thank you
04-08-2013 03:18 PM
Dear
Thank you
04-08-2013 03:24 PM
Thanks Kamal , i will prepare the requirements and shqre it with you.
04-08-2013 03:25 PM
Jack,
Let us know what you need and we can help you.
You will need a DMM server besides the SnS server. This is used to manage the SnS users and integrate with Active Directory.
The best release for a new SnS with CAST is 5.3.5
Also how do you plan to get the TV signal to CAST (IPTV replacement)?
There is a lot of information here
http://www.cisco.com/en/US/partner/products/ps6682/tsd_products_support_series_home.html
John
04-11-2013 07:25 PM
Thanks Jde &kamal for help
i have (video cams ) as input and some archive and i need to convert all of them through IP network to be displayed by LCDs using DMS solution , I need also to allow IPTV for 300 DMP . That is all , i nead to design a perfect design .Can you help me.
04-17-2013 06:12 PM
Hello
Thank you
04-19-2013 04:16 AM
thanks for your help ,i need more details and links for documentation please and i need also guide for installation.
04-22-2013 10:42 PM
Hello
Hello
Thank you
04-22-2013 10:45 PM
Hello
Thank you
Islam Kamal
04-25-2013 08:46 AM
hello
kamal help please for
1-IPTV solution ?.
2-How can i do design using my running headends to allow IPTV through my network?.
3-What about redundancy for SNS and digital signage?.
4-Share to me any usefull documents ?.
thanks
04-25-2013 04:55 PM
hello
Thank you
04-25-2013 05:00 PM
hello
04-25-2013 05:04 PM
hello
Thank you
04-25-2013 05:04 PM
Hello
Thank you
04-25-2013 05:06 PM
Hello
thank you
