08-11-2004 10:37 PM - edited 03-13-2019 05:59 AM
hello. i have two questions.
Q.1
i debugging with debug mgcp packet.
below list.
Aug 12 15:22:42.899: send_mgcp_msg, MGCP Packet sent to 192.168.0.99:2427 --->
Aug 12 15:22:42.899: NTFY 570 *@KrisNet MGCP 0.1
X: 0
O:
Aug 12 15:22:42.903: MGCP Packet received from 192.168.0.99:2427-
200 570
Aug 12 15:22:57.900: send_mgcp_msg, MGCP Packet sent to 192.168.0.99:2427 --->
Aug 12 15:22:57.900: NTFY 571 *@KrisNet MGCP 0.1
X: 0
O:
Aug 12 15:22:57.904: MGCP Packet received from 192.168.0.99:2427-
200 571
at first , i make route group and i make route list.
at last i make route pattern ,but route list's status
is NOT FOUND.
above debugging message , does not cm connect FXO PORT ? .I think fxo port does not resgister from cm.
Q.2
and i append my router configuring.
ip dhcp pool e
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
option 150 ip 192.168.0.99
dns-server 210.94.0.73 210.220.163.82
netbios-name-server 210.96.0.73 210.220.163.82
ip dhcp pool voice
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
voice-card 1
voice service pots
voice service voip
voice class codec 1
codec preference 1 g711ulaw
ccm-manager mgcp
fax interface-type fax-mail
class-map match-all class1
match access-group 101
policy-map policy1
class class1
bandwidth 3000
random-detect
random-detect precedence 0 32 256 100
translation-rule 1
Rule 0 ^80 0
Rule 1 ^81 1
Rule 2 ^800 00
translation-rule 2
Rule 0 ^90 0
Rule 1 ^91 1
translation-rule 3
Rule 0 ^71 1
Rule 1 ^70 0
Rule 3 ^78 8
interface FastEthernet0/0
ip address 192.168.1.2 255.255.255.0
service-policy output policy1
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip tech-prefix 8#
ip rtp priority 16384 16383 40
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1
encapsulation dot1Q 1 native
ip address 192.168.0.1 255.255.255.0
interface FastEthernet0/1.2
encapsulation dot1Q 2
ip address 192.168.2.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip http server
ip http path flash:
ip nat pool local 211.179.18.195 211.179.18.195 prefix-length 29
ip nat inside source list 1 pool local overload
ip nat inside source static 192.168.0.50 !
access-list 1 permit 192.168.0.0 0.0.0.255
voice-port 1/0/1
voice-port 1/0/2
voice-port 1/0/3
voice-port 1/1/0
voice-port 1/1/1
mgcp
mgcp call-agent 192.168.0.99 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp profile default
dial-peer voice 222 voip
destination-pattern T
voice-class codec 1
session target ras
no vad
dial-peer voice 22 pots
destination-pattern 155
fax rate voice
port 1/1/1
dial-peer voice 444 voip
destination-pattern 101
session target ipv4:218.152.164.110
dial-peer voice 2 pots
preference 7
application mgcpapp
port 1/0/0
forward-digits 0
dial-peer voice 3 pots
application mgcpapp
no digit-strip
port 1/0/1
forward-digits 0
dial-peer voice 23 pots
destination-pattern 117
port 1/1/0
gateway
inbound call is sucess,but outbound call is failed.
is my configuring false ?
and my ios version is C2600 Software (C2600-IPVOICE-M), Version 12.3(7)T
plz help me
08-17-2004 12:37 PM
Please refer the following link...
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008017b2ad.shtml
