Help with autoregistration
I have my call manager set up for auot registration. I have a 7960 and 7910 phone. DHCP is giving the phones the correct config, but for some reason the phones never completely register. I see this message constantly on the 7960, "Defaulting CM to TFTP Server". What does this mean. The 7910 just says opening 192.168.1.1, which is the IP address to default router. I appreciate any help.
kthorngr
Usually this means that there is some sort of network connectivity issue:
- Is your Cisco TFTP server running and does the phone have IP connectivity to it?
- Are you using IP address or name for your Call Managers. If name please make sure the DNS parameters are correct.
- Erase the configuration on the IP Phones and try them again.
Is this a new installation or has this problem just started? Is the problem limited to a certain number of phones?
I checked the TFTT Service on my Call Manager and it is running.
I am using the IP address for the Call Manager.
I erased the config on the phones.
It is a new installation. I only have two phones and both of them have a problem. One is a 7910, it has a different error message. It says, "Opening 192.168.1.1"(default router) and "jOpening 192.168.1.200 (Call Manager/TFTP Server).
I can ping the phones from the Call Manager/TFTP Server.
Problem still exists...what else can I try.
You were right! It was a network connectivity issue. I checked everything again and I realized the typo that I made. My DHCP server was assinging 192.168.1.2 as the TFTP server, when it should have been 192.168.1.200.
My fault, cockpit error.
Bruce
