How can echo be introduced on an ip phone to ip phone call?
admin_2
Level 3
Level 3
We are have a problem with echo being intorduced on ip phone to ip phone calls. Most of the time they are on the same LAN. My understanding is that is this situation the echo can only be intoduced by the handset or speaker. Is this true? What is the best way to elliminate this type of echo?
Not applicable
The bearer path used an ip phone
to ip phones is rtp/udp/ip and hence digital
which mean no leak can occur.
However Acoustic echo is a major concern for
handsfree speakerphone terminals. The air
(and the terminal plastics) provides mechanical
or acoustical coupling between the
loudspeaker and the microphone. Speakerphone
manufacturers combat this with good acoustic design
of terminals, directional microphones, and acoustic
echo cancellers/suppressors in the terminal. However,
this is a very difficult problem, and speakerphones
are inherently poor in terms of echo.
The echo is probably introduce becaue you're using spearker phone
in a noisy area i.e a lab envirnoment.
try to call, using the handset and see what happens. Also if the phone
you're calling is not too far way from each other and one end is using speaker phone,
the echo would probably be a lot irritating ( louder).
