How can I enable FTP on the DMP and How can I FTP to it and then remove the files that were deployed to the DMP flash?
jagifoto1
How can I enable FTP on the DMP and How can I FTP to it and then remove the files that were deployed to the DMP flash? My platform of DMS is 5.2.2
Temur Kalandia
hi jagifoto1
you can enable FTP service from DMP menu management services, then enable ftp.
from DMP service account page change the password of the ftp account , username is ftp;
use  ftp:///tmp/ftproot/usb_1/ — For files on the internal flash drive
       ftp://tmp/ftproot/usb_2/ — For files on a mounted USB drive
       ftp://tmp/ftproot/CIFS/ — For files on a mounted network share
to delete all files from DPMs create this advanced task:
Advanced Tasks--> System Tasks
Name\Description = Clean USB1 on DMP
Request Type     = Set
Request          = mng.command=write+sh+FG+rm+-rf+/tmp/ftproot/usb_1/
Name\Description = Clean USB2 on DMP
Request Type     = Set
Request          = mng.command=write+sh+FG+rm+-rf+/tmp/ftproot/usb_2/
Temur Kalandia
hi jagifoto1
Request Type     = Set
Request Type     = Set
Hi Temur, ok. I do the above procedure and it worked fine
Now, I have other question?
How can I reproduce any file (for example: a video, an url page, an image), that is in the flash of DMP?
Índice de ftp://172.17.15.22/tmp/ftproot/tmp/ftproot/tmp/ftproot/usb_1/
Subir al directorio superior.
Nombre Tamaño Última modificación
Archivo:Sample Videos.lnk1 KB17/06/201106:25:00 a.m.
deployment
29/06/201004:14:00 a.m.
lost+found
25/02/201012:00:00 a.m.
Archivo:video futbol en la playa.mp41390 KB29/06/201001:08:00 a.m.
Archivo:videofutbol.mp41390 KB29/06/201001:38:00 a.m.
I like, that el DMP when loss conectivity with DMM, It display at the LCD screen, the video named Archivo:videofutbol.mp4, this video As I show in the picture above, already in the flash of DMP.
I appreciate your early response.
Hi jagifoto1
As i guesed you need to push all contents to DMP's and after that play them, no metter if there connectivity lost.
    firstly you need to upload all your content to DMP's. this can be done from digital signage menu Digital media players/Advanced task.  create new deployment package, in process of creation you can choose several content types.
    after you use menu Schedule (play now, or play in future option), select event type adavanced tasks
and chpoose deployment package you 've created before. after finishing deployment the new link is generated in advanced task/(go to) url menu. it means tha you uploaded video on DMP's.
   after uploading videos you you must schedule again to play those uloaded content. go to menu schedule, select event type advanced task and choose newly generated url's to play.
  regards
