How can I route calls of ISDN BRI S/T, to my 6 ip phones?
petazetas754
I have a 1760 Router a 6 iphones (2port FXO,ISDN BRI,FXS)
and Callmanager Express 3.0
I want a voice call from ISDN BRI S/T to be routed to one iphone for example the one with number 006
Does anybody knows how?
Thanks.
thisisshanky
Level 11
Level 11
Is your CME up and running or still you need help with that configuration ? Is your ISDN BRI circuit provisioned for voice ? If yes, configure the phones registered to the CME router with the same number of digits as the service provider is sending across on the ISDN line. For ex; 9724502006 is the 10 digit number for which the service provider sends you 006. You can configure one of the IP phones with extension 006.
To read more about configuring and administering CME router, go here:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_configuration_guide_chapter09186a00801f12a2.html
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Thanks a lot, my ISDN BRI is provisioned for voice a im going to try it.....
My isdn number is "942291236" and thats my router configuration:
Cisco1700#show config
Using 2725 out of 29688 bytes
! Last configuration change at 07:02:16 GMT Sat Oct 2 2004
! NVRAM config last updated at 07:02:51 GMT Sat Oct 2 2004
version 12.2
hostname Cisco1700
logging queue-limit 100
enable secret xxxx
enable password xxx
clock timezone GMT 1
ip subnet-zero
ip dhcp pool dynamicserver
network 128.100.0.0 255.255.0.0
option 150 ip 128.100.110.40
default-router 128.100.110.40
isdn switch-type basic-net3
voice class h323 1
no voice hpi capture buffer
no voice hpi capture destination
mta receive maximum-recipients 0
interface FastEthernet0/0
ip address 128.x.x.x.255.0.0
speed auto
half-duplex
interface BRI0/0
no ip address
isdn incoming-voice voice
interface Serial1/0
no ip address
shutdown
interface Serial1/1
no ip address
shutdown
ip classless
ip http server
ip http path flash
snmp-server community public RO
snmp-server enable traps tty
call rsvp-sync
voice-port 2/0
cptone ES
connection plar 005
voice-port 2/1
connection plar 005
voice-port 3/0
voice-port 3/1
mgcp profile default
dial-peer cor custom
dial-peer voice 1 pots
incoming called-number 005
destination-pattern 9
port 2/0
dial-peer voice 2 pots
destination-pattern 007
port 3/0
telephony-service
load 7905 CP79050101SCCP030530B
max-ephones 24
max-dn 120
ip source-address 128.100.110.40 port 2000
create cnf-files version-stamp 7960 Oct 02 2004 06:54:53
max-conferences 6
web admin system name xxxx password xxxx
dn-webedit
time-webedit
ephone-dn 1 dual-line
number 001 no-reg both
name Telematica1
hold-alert 30 originator
ephone-dn 2 dual-line
number 002 no-reg both
name Telematica2
ephone-dn 3 dual-line
number 003 no-reg both
name Telematica3
ephone-dn 4 dual-line
number 005 no-reg both
name Telematica5
ephone-dn 5 dual-line
number 006 no-reg both
name Telematica6
ephone-dn 6 dual-line
number 004
name telematica4
ephone 1
mac-address 000D.EDAB.653A
button 1:1
ephone 2
mac-address 000D.EDC3.6723
button 1:5
ephone 3
mac-address 000D.EDAB.6327
button 1:3
ephone 4
mac-address 000E.386E.DD9B
button 1:2
ephone 5
mac-address 000D.EDAB.648C
button 1:4
ephone 6
mac-address 000E.386D.D29B
type 7905
button 1:6
line con 0
speed 115200
line aux 0
line vty 0 4
password xxx
login
ntp server 128.250.36.2
end
Some advice?
Please ,can you explain me a bit more and with a little example the theme of put my isdn number 942291236 with my phone numbers? that are 001 002 003 004 005 006
Thanks a lot.
