How Do I Factory Reset An Edge300
Steven Allison
Trying to get this done as the device appears 'stuck' on a single application after registering it to on-premise Appspace server.
I need to reset this thing to factory defaults - don't seem to be able to access the device desktop either.
Thanks.
Nicolas Fournier
Hi Steven,
The procedure to reset an edge to factory default is to press the reset button for 5 seconds.
If it doesn't work, you might need to re-image the device using the following procedure: http://www.cisco.com/c/en/us/td/docs/switches/lan/cisco_edge_300/software/release/1_4/configuration/guide/ce300cg_book/Trouble.html
Nicolas
