09-28-2011 08:10 PM - edited 03-13-2019 07:32 PM
Where and how do I check if there is packets being lost between my call manager which is version 4.1 and my cisco 7941 IP phones, keep in mind my phones show register all the time I just need to know if packets are being dropped when I transfer a call.
Horacio.
Solved! Go to Solution.
09-30-2011 11:19 PM
Hi Horacio
On the screen :-)
If you don't see them, you may not have tapped ? twice quickly enough.
Aaron
09-30-2011 05:32 AM
You may just double press the ? button on the phone while the call is active this will give you the statistics of the call, or you may setup a sniffer trace on both switchports and check if you are missing some data.
Are you experiencing any kind of problem/symptom ???
Christian Nuche
PDI Team.
09-30-2011 08:48 AM
Hello Christian,
Where do you see the statistics after you pressed the ? button.
09-30-2011 11:19 PM
Hi Horacio
On the screen :-)
Aaron
