Inmediate disconnect after CONNECT ACK
jgomez
I´m getting inmediate disconnect in outgoing calls
through 1751 with VIC-2BRI, 2 DSPs, 12.2(15).T11 and Spanish BRI lines. Configured as H323 gateway in CCM.
After receiving CONNECT ACK, I see Disconnect
with Cause: Information element not implemented.
Seems it isn´t able to get a B-channel.
I tried forcing Called Numbering Plan to Unknown
but no effect.
Line works fine when directly connected to an ISDN
phone.
This is part of the config:
interface BRI2/1
no ip address
isdn switch-type basic-net3
isdn incoming-voice voice
voice-port 2/1
compand-type a-law
bearer-cap Speech
dial-peer voice 2 pots
destination-pattern T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
no digit-strip
direct-inward-dial
port 2/1
Any suggestions would be highly appreciated.
Alvaro
jgugler
Hello
i have the same problem here with Switzerland line (basic-net3)
The configuration is ths same and I get the following :
May 14 08:54:19.449: ISDN BR1/0 EVENT: process_bri_call: call id 0x8018, called_
number 0313859874, Guid 1A61BD18805Aspeed 0, call type VOICE, calling_number 031
3859074
May 14 08:54:19.449: ISDN BR1/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0
x0, Calling num 0313859074
May 14 08:54:19.453: ISDN BR1/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0
x0, Called num 0313859874
May 14 08:54:19.453: ISDN BR1/0 Q931: TX -> SETUP pd = 8 callref = 0x14
Bearer Capability i = 0x8090A2
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x81
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0080, '0313859074'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '0313859874'
May 14 08:54:19.537: ISDN BR1/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x94
Cause i = 0x82E404 - Invalid information element contents
May 14 08:54:19.541: ISDN BR1/0 EVENT: process_rxstate: ces/callid 1/0x8018 call
type 2 HOST_DISCONNECT_ACK
Are you using "compand-type a-law"?
I get a similar error when trying with
compand-type u-law.
Congratulation, it works very well !!!!
Thanks a lot
OK, could you please send me your config.
to see if it helps me with my problem?
My email is adiez@genetsis.com
Do you use the default value "CallManager" for
the Called Numbering Plan, etc?
