Integrate Cisco with Panasonic with R2
heri.sugianto
Hi All,
right know I'm trying to integrate cisco voice gateway with panasonic TDA600, with topologi as follow
x7199-------FXS----CISCO2811------E1-----------------------E1-----Panasonic--------x4322
I can't call extension 4322 from extension 7199 and viva versa.
the configuration on voice gateway is as following
Router#sh run
Building configuration...
Current configuration : 1709 bytes
! Last configuration change at 12:18:52 UTC Wed May 4 2011 by cisco
version 15.1
hostname Router
boot-start-marker
boot-end-marker
card type e1 0 3
no aaa new-model
network-clock-participate wic 3
dot11 syslog
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
voice service pots
voice-card 0
dspfarm
dsp services dspfarm
license udi pid CISCO2821 sn FTX1309A0B2
username cisco privilege 15 password 0 cisco
controller E1 0/3/0
framing NO-CRC4
ds0-group 1 timeslots 1-15,17-31 type r2-analog r2-non-compelled ani
cas-custom 1
  metering
  dnis-complete
controller E1 0/3/1
interface GigabitEthernet0/0
ip address 10.14.22.173 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.14.22.173
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
voice-port 0/0/0
cptone ID
station-id number 7199
voice-port 0/0/1
station-id number 7190
voice-port 0/3/0:1
cptone GB
mgcp profile default
dial-peer voice 40 pots
destination-pattern 7199
port 0/0/0
forward-digits all
dial-peer voice 41 pots
destination-pattern ....
direct-inward-dial
port 0/3/0:1
forward-digits all
line con 0
logging synchronous
login local
line aux 0
line vty 0 4
logging synchronous
login local
transport input all
scheduler allocate 20000 1000
end
I had using "debug voice ccapi inout" with result as following
Router#debug voice ccapi inout
voip ccapi inout debugging is on
Router#
Router#
Router#
Router#
Router#
Router#
*May  4 12:23:51.725: //-1/xxxxxxxxxxxx/VTSP:(0/0/0):-1:-1:-1/vtsp_allocate_cdb:
   CDB=0x49650EA0
*May  4 12:23:51.725: //-1/xxxxxxxxxxxx/VTSP:(0/0/0):-1:-1:-1/vtsp_do_call_setup_ind:
   Event=E_TSP_SETUP_IND
   Progress Indication=3, CarrierIDCode=, Info Trans Capability=144, Source Carrier ID=, tg_label_flag=0
   Calling Number=7199, TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed
   CLIR=FALSE, CLID Transparent=FALSE, Null Originating Calling Number=FALSE, Calling Translated=FALSE
*May  4 12:23:51.725: //-1/3471E98A834A/VTSP:(0/0/0):-1:-1:-1/vtsp_timer:
   Timer Start Time=2951539, Timer Value=180000(ms)
*May  4 12:23:51.725: //-1/3471E98A834A/VTSP:(0/0/0):-1:-1:-1/vtsp_insert_cdb:
*May  4 12:23:51.725: //-1/3471E98A834A/VTSP:(0/0/0):-1:1:1/act_setup_ind_pend_success:
*May  4 12:23:51.725: //-1/3471E98A834A/VTSP:(0/0/0):-1:1:1/vtsp_realloc_cdb:
   CDB=0x49650EA0
*May  4 12:23:51.725: //-1/3471E98A834A/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=7199
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*May  4 12:23:51.729: //-1/3471E98A834A/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x48DF64E0, Call Info(
   Calling Number=7199,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=40, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
*May  4 12:23:51.729: //-1/3471E98A834A/CCAPI/ccCheckClipClir:
   In: Calling Number=7199(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=7199(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
*May  4 12:23:51.729: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*May  4 12:23:51.729: :cc_get_feature_vsa malloc success
*May  4 12:23:51.729:  cc_get_feature_vsa count is 1
*May  4 12:23:51.729: :FEATURE_VSA attributes are: feature_name:0,feature_time:1232236736,feature_id:383
*May  4 12:23:51.729: //383/3471E98A834A/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=7199(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
*May  4 12:23:51.729: //383/3471E98A834A/VTSP:(0/0/0):-1:1:1/vtsp_insert_cdb:
*May  4 12:23:51.729: //383/3471E98A834A/VTSP:(0/0/0):-1:1:1/vtsp_timer:
*May  4 12:23:51.729: //383/3471E98A834A/CCAPI/cc_process_call_setup_ind:
   Event=0x489D4F50
*May  4 12:23:51.729: //383/3471E98A834A/CCAPI/ccCallSetContext:
   Context=0x49749C68
   >>>>CCAPI handed cid 383 with tag 40 to app "_ManagedAppProcess_Default"
*May  4 12:23:51.729: //383/3471E98A834A/CCAPI/ccCallSetupAck:
   Call Id=383
*May  4 12:23:51.729: //383/3471E98A834A/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
*May  4 12:23:51.733: //383/3471E98A834A/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=383
*May  4 12:23:51.733: //383/3471E98A834A/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
*May  4 12:23:51.733: //383/3471E98A834A/CCAPI/ccCallReportDigits:
   (callID=0x17F, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=383
*May  4 12:23:51.733: //383/3471E98A834A/VTSP:(0/0/0):-1:1:1/vtsp_report_digit_control:
*May  4 12:23:51.733: //383/3471E98A834A/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x48DF64E0, callID=0x17F, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Router#Enabled=TRUE, Disposition=0x0, Interface=0x48DF64E0, Call Id=383
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
   Digit Reporting=TRUE
*May  4 12:23:51.733: //383/3471E98A834A/VTSP:(0/0/0):-1:1:1/act_setup_ind_ack:
   Fax Relay=TRUE, Dial Tone=TRUE, Digit Collect=TRUE, Overlap=FALSE, DID=FALSE
*May  4 12:23:51.733: //383/3471E98A834A/VTSP:(0/0/0):-1:1:1/vtsp_timer_stop:
   Timer Stop Time=2951540
Router#
*May  4 12:23:53.337: //383/3471E98A834A/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x1, Destination Call Id=-1,
   Source Call Id=383, Digit=4, DigitBeginFlags=0x1,
   Rtp Timestamp=0xBD19647B, Rtp Expiration=0x0
*May  4 12:23:53.417: //383/3471E98A834A/VTSP:(0/0/0):-1:1:1/vtsp_timer_stop:
   Timer Stop Time=2951708
*May  4 12:23:53.417: //383/3471E98A834A/CCAPI/cc_api_call_digit_end:
   Source Call Id=383, Digit=4, Duration=115,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
   Call Entry(Handoff Depth=0)
*May  4 12:23:53.793: //383/3471E98A834A/CCAPI/cc_api_call_digit_begin:
   Source Call Id=383, Digit=3, DigitBeginFlags=0x1,
   Rtp Timestamp=0xBD1972D6, Rtp Expiration=0x0
*May  4 12:23:53.877: //383/3471E98A834A/VTSP:(0/0/0):-1:1:1/vtsp_timer_stop:
   Timer Stop Time=2951754
*May  4 12:23:53.877: //383/3471E98A834A/CCAPI/cc_api_call_digit_end:
Router#Destination Interface=0x0, Destination Mask=0x1, Destination Call Id=-1,
   Source Call Id=383, Digit=3, Duration=120,
*May  4 12:23:54.133: //383/3471E98A834A/CCAPI/cc_api_call_digit_begin:
   Source Call Id=383, Digit=2, DigitBeginFlags=0x1,
   Rtp Timestamp=0xBD197D7B, Rtp Expiration=0x0
*May  4 12:23:54.217: //383/3471E98A834A/VTSP:(0/0/0):-1:1:1/vtsp_timer_stop:
   Timer Stop Time=2951788
*May  4 12:23:54.217: //383/3471E98A834A/CCAPI/cc_api_call_digit_end:
   Source Call Id=383, Digit=2, Duration=115,
*May  4 12:23:54.445: //383/3471E98A834A/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0xBD19872E, Rtp Expiration=0x0
*May  4 12:23:54.525: //383/3471E98A834A/VTSP:(0/0/0):-1:1:1/vtsp_timer_stop:
   Timer Stop Time=2951819
*May  4 12:23:54.525: //383/3471E98A834A/CCAPI/cc_api_call_digit_end:
   Source Call Id=383, Digit=2, Duration=112,
*May  4 12:23:54.525: //383/3471E98A834A/CCAPI/ccCallReportDigits:
   (callID=0x17F, digit_event=0x0, enable=FALSE, consume=FALSE)
*May  4 12:23:54.525: //383/3471E98A834A/VTSP:(0/0/0):-1:1:1/vtsp_report_digit_control:
*May  4 12:23:54.525: //383/3471E98A834A/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x48DF64E0, callID=0x17F, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
   Digit Reporting=FALSE
*May  4 12:23:54.525: //383/3471E98A834A/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
*May  4 12:23:54.529: //383/3471E98A834A/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=41, Params=0x4974D8D0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*May  4 12:23:54.529: //383/3471E98A834A/CCAPI/ccCheckClipClir:
   Destination Pattern=...., Called Number=4322, Digit Strip=TRUE
   Called Number=4322(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=FALSE,
   Guid=3471E98A-7580-11E0-834A-958849EB78C9, Outgoing Dial-peer=41
*May  4 12:23:54.529: //383/3471E98A834A/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=7199
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=4322
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
*May  4 12:23:54.529: //383/3471E98A834A/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x49418D28, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=7199,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=4322(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=41, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*May  4 12:23:54.529: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*May  4 12:23:54.529: :cc_get_feature_vsa malloc success
*May  4 12:23:54.529:  cc_get_feature_vsa count is 2
*May  4 12:23:54.529: :FEATURE_VSA attributes are: feature_name:0,feature_time:1232236960,feature_id:384
*May  4 12:23:54.529: //-1/xxxxxxxxxxxx/VTSP:(0/3/0:1):-1:-1:-1/vtsp_allocate_cdb:
   CDB=0x49651178
*May  4 12:23:54.529: //-1/xxxxxxxxxxxx/VTSP:(0/3/0:1):-1:-1:-1/vtsp_insert_cdb:
*May  4 12:23:54.529: //384/3471E98A834A/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
*May  4 12:23:54.529: //384/3471E98A834A/CCAPI/ccCallSetContext:
   Context=0x4974D880
*May  4 12:23:54.529: //383/3471E98A834A/CCAPI/ccSaveDialpeerTag:
*May  4 12:23:54.533: //383/3471E98A834A/VTSP:(0/0/0):-1:1:1/act_dcollect_proc:
*May  4 12:23:54.533: //384/3471E98A834A/VTSP:(0/3/0:1):-1:-1:-1/vtsp_og_call_req:
   Echo Cancel=TRUE, Gain Control=0
   Auto Gain Control=FALSE, Dual Tone Detect Mask=0x0, Seq Tone Detect=FALSE
*May  4 12:23:54.533: //384/3471E98A834A/VTSP:(0/3/0:1):-1:1:2/act_setup_req_pend_succ:
*May  4 12:23:54.533: //384/3471E98A834A/VTSP:(0/3/0:1):-1:1:2/vtsp_request_call:
   Mode=0, Peer=41
   Progress Indication=3, Info Trans Capability=144
   Called Number=4322, TON=Unknown, NPI=Unknown
*May  4 12:23:54.737: //384/3471E98A834A/VTSP:(0/3/0:1):-1:1:2/act_setup_pend_proceeding:
*May  4 12:23:54.737: //384/3471E98A834A/VTSP:(0/3/0:1):-1:1:2/vtsp_timer:
   Timer Start Time=2951840, Timer Value=25000(ms)
*May  4 12:23:54.737: //384/3471E98A834A/CCAPI/cc_api_call_proceeding:
   Interface=0x49418D28, Progress Indication=NULL(0)
   Peer=41, Progress Indication=0, Return Code=2
Router#
*May  4 12:23:54.737: //384/3471E98A834A/VTSP:(0/3/0:1):-1:1:2/act_setup_req_pend_defer:
   Event=19
*May  4 12:23:54.737: //384/3471E98A834A/VTSP:(0/3/0:1):-1:1:2/act_setup_req_wait_pend_success:
   Event=75
*May  4 12:23:54.737: //384/3471E98A834A/VTSP:(0/3/0:1):-1:1:2/vtsp_timer_stop:
   Timer Stop Time=2951840
*May  4 12:23:54.737: //384/3471E98A834A/VTSP:(0/3/0:1):-1:1:2/act_setup_r2_pend_dial:
   Digits=4#3#2#B#1#7#1#9#9#*#2#, Tone Mode=1
*May  4 12:23:54.737: //384/3471E98A834A/VTSP:(0/3/0:1):-1:1:2/ds_do_dial:
   Digits To Dial=4#3#2#B#1#7#1#9#9#*#2#
*May  4 12:23:55.309: //384/3471E98A834A/VTSP:(0/3/0:1):-1:1:2/ds_dialing_release:
*May  4 12:23:55.309: //384/3471E98A834A/VTSP:(0/3/0:1):-1:1:2/ds_dial_event_check:
*May  4 12:23:55.309: //384/3471E98A834A/VTSP:(0/3/0:1):-1:1:2/act_setup_pend_dial_comp:
*May  4 12:23:55.309: //384/3471E98A834A/VTSP:(0/3/0:1):-1:1:2/act_setup_pend_release_ind:
   Cause Value=16
*May  4 12:23:55.309: //384/3471E98A834A/VTSP:(0/3/0:1):-1:1:2/vtsp_ring_noan_timer_stop:
   Timer Stop Time=2951897
*May  4 12:23:55.309: //384/3471E98A834A/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x49418D28, Call Id=384
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
*May  4 12:23:55.309: //384/3471E98A834A/VTSP:(0/3/0:1):-1:1:2/vtsp_set_release_source:
   Release Direction=PSTN, Release Source=Called Party-PSTN
   Peer=41
*May  4 12:23:55.309: //383/3471E98A834A/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
*May  4 12:23:55.309: //384/3471E98A834A/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=384
*May  4 12:23:55.309: //384/3471E98A834A/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Router#
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
*May  4 12:23:55.309: //384/3471E98A834A/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
*May  4 12:23:55.309: //384/3471E98A834A/VTSP:(0/3/0:1):-1:1:2/act_host_disc_cleanup:
   dsm_indicate_error=0, short_cleardown_timeout=0, Mode=0
   Exit State=16
Router#
*May  4 12:23:58.769: //384/3471E98A834A/VTSP:(0/3/0:1):-1:1:2/act_dsm_dsp_stats_complete:
*May  4 12:23:58.769: //384/3471E98A834A/VTSP:(0/3/0:1):-1:1:2/vtsp_timer:
   Timer Start Time=2952243, Timer Value=60000(ms)
*May  4 12:23:58.773: //384/3471E98A834A/VTSP:(0/3/0:1):-1:1:2/act_wrelease_release:
*May  4 12:23:58.773: //384/3471E98A834A/VTSP:(0/3/0:1):-1:1:2/vtsp_play_busy_timer_stop:
   Timer Stop Time=2952244
*May  4 12:23:58.773: //384/3471E98A834A/VTSP:(0/3/0:1):-1:1:2/vtsp_timer_stop:
*May  4 12:23:58.773: //384/3471E98A834A/VTSP:(0/3/0:1):-1:1:2/vtsp_is_valid_dsm_handle:
   DMGR=0x48B68FE0, VTSP CDB=0x49651178
*May  4 12:23:58.773: //384/3471E98A834A/VTSP:(0/3/0:1):-1:-1:-1/act_terminate:
*May  4 12:23:58.773: //384/3471E98A834A/VTSP:(0/3/0:1):-1:-1:-1/vtsp_timer_stop:
*May  4 12:23:58.773: //384/3471E98A834A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49418D28, Tag=0x0, Call Id=384,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*May  4 12:23:58.773: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*May  4 12:23:58.773: :cc_free_feature_vsa freeing 49727198
*May  4 12:23:58.773:  vsacount in free is 1
*May  4 12:23:58.773: //-1/3471E98A834A/VTSP:(0/3/0:1):-1:-1:-1/vtsp_free_cdb:
   CDB=0x49651178
*May  4 12:23:58.777: //383/3471E98A834A/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
*May  4 12:23:58.777: //383/3471E98A834A/CCAPI/cc_api_get_transfer_info:
*May  4 12:23:58.777: //383/3471E98A834A/VTSP:(0/0/0):-1:1:1/act_pre_con_disconnect:
Router#
   Cause Value=16, Hairpin=FALSE
*May  4 12:23:58.777: //383/3471E98A834A/VTSP:(0/0/0):-1:1:1/vtsp_timer_stop:
*May  4 12:23:58.777: //383/3471E98A834A/VTSP:(0/0/0):-1:1:1/vtsp_ring_noan_timer_stop:
*May  4 12:23:58.777: //383/3471E98A834A/VTSP:(0/0/0):-1:1:1/act_pre_con_disconnect:exit@1027
*May  4 12:23:59.829: //383/3471E98A834A/VTSP:(0/0/0):-1:1:1/act_wrelease_release:
*May  4 12:23:59.829: //383/3471E98A834A/VTSP:(0/0/0):-1:1:1/vtsp_play_busy_timer_stop:
   Timer Stop Time=2952349
*May  4 12:23:59.829: //383/3471E98A834A/VTSP:(0/0/0):-1:1:1/vtsp_timer_stop:
*May  4 12:23:59.829: //383/3471E98A834A/VTSP:(0/0/0):-1:1:1/vtsp_is_valid_dsm_handle:
   DMGR=0x4979B68C, VTSP CDB=0x49650EA0
*May  4 12:23:59.829: //383/3471E98A834A/VTSP:(0/0/0):-1:-1:-1/act_terminate:
*May  4 12:23:59.829: //383/3471E98A834A/VTSP:(0/0/0):-1:-1:-1/vtsp_timer_stop:
Router#
*May  4 12:23:59.833: //383/3471E98A834A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x48DF64E0, Tag=0x0, Call Id=383,
*May  4 12:23:59.833: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*May  4 12:23:59.833: :cc_free_feature_vsa freeing 497270B8
*May  4 12:23:59.833:  vsacount in free is 0
*May  4 12:23:59.833: //-1/3471E98A834A/VTSP:(0/0/0):-1:-1:-1/vtsp_free_cdb:
   CDB=0x49650EA0
Could any one help me on this.
Br,
Heri
paolo bevilacqua
Are you sure about the R2 parameters? You should configure a country also.
Hi Paolo,
thanks for your respond.
i had tried using country option, but still no result.
is there any suggestion ?
Br,
Heri
Rahman Dani
Level 4
Level 4
Hi Heri,
I have assume your L2 is done and no issue w/ R2 integration (show controller e1 status is up)
please add this config
dial-peer voice 1 pots
incomming called-number .
direct-inward-dial
! to make sure, when your inbounce call down is used correct inbounce dial-peer
destination-pattern 4...
port 0/3/0:1
forward-digits 4
! for outgoing call test with most spesific dial-peer..
look at "debug voip dial-peer" & "terminal monitor" to make sure your incomming and outgoing used correct dial-peer
