03-01-2006 10:16 AM - edited 03-13-2019 12:21 PM
What type of integration is there between a BCM 1000 or 50 and CME and Unity Express? Can we setup 4 digit dialing using h.323? We are placing a CME router at a remote site that is connected via PPP T1 into the main office which has a Nortel BCM 1000 running 3.6.
Any assistance is greatly appreciated!
Thank you,
Jesse Pike
03-07-2006 11:39 AM
Before doing the following tasks to integrate Cisco Unity with the Nortel Meridian/PBXLink phone system, confirm that the Cisco Unity server is ready for the integration by completing the applicable tasks in the applicable Cisco Unity installation guide.
The following task lists describe the process for creating, changing, and deleting integrations.
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/prod_configuration_guide09186a00801171e4.html
09-20-2010 12:50 PM
Hello - The link is no longer available.
03-30-2006 11:57 AM
Were you able to make this integration work? I have a customer that is wanting to setup the same type of integration and have been looking for information.
Robert Bailey
04-01-2006 11:21 PM
We were able to get this setup with the assistance of Nortel. Here are the requirements on the BCM in addition to the configurations for CME (probably similar for CM).
In a nutshell you need at least 3.6 running on the BCM
Nortel BCM 1000 attributes:
BCM 3.6 2.2c
Load these patches in order on the BCM
BCM_360[1].236_FEPS.33.371600.exe
BCM_360[1].259_CUMULATIVE.99.3.exe
BCM_360[1].252_CORE.08.0621.exe
Make sure calls are made through destinations codes and not access codes Under destination codes absorbed all Enable H245 Disable and enable the H323 VoIP gateway
Cisco IOS version 12.4.4XC using CME 4.0.1 Ensure voice service's on the router are as follows:
voice call send-alert
voice service voip
allow-connections h323 to sip
fax protocol pass-through g711ulaw
h323
modem passthrough nse codec g711ulaw
voice class codec 1
codec preference 1 g711ulaw
voice class h323 1
h225 timeout tcp establish 3
call start slow
call preserve
