10-13-2006 12:52 AM - edited 03-13-2019 03:22 PM
I have an interesting problem.
I have setup a non-gatekeeper InterCluster trunk, between my CM 3.1 and CM 5.0(4).
Approx 50% of calls seem to go through when I dial from CM 5.0(4) to CM 3.
When they dont connect, in the trace, I see
wait_AuConnectErrorInd - send disconn to 1 MXs|<CLID::StandAloneCluster><NID::callmanager5><CT::1,100,15,88.5><IP::10.1.3.2><DEV::Port 3092><LVL::Error><MASK::0800>
In all cases, the called part alerts, and sees the caller id.
Media caps are also exchanged.
Its at the time of media connection, that the call seems to drop.
Having a MTP on one or both ends of the trunk also does not seem to solve the problem.
Attached is a trace file of 2 calls in quick succession.
The first once from 1000 to 489980 succeeds, while the second one, made a few seconds later, fails !!
Any tips would be highly appriciated.
11-16-2006 09:16 AM
Hi, there,
Have you found the reason of this problem?
It seems I met the same kind of trouble. I set up an inter-cluster trunk between ccm4.1 and 3.3. And 50% calls got fast busy tone.
could you share some idea with me?
thanks,
11-17-2006 09:05 AM
Unfortunately I have not figured this out yet, but some config tewaking seems to reduce the number of fast-busys.
Since my setup is an experimental system only, I am the only one making calls and testing, so I am not sure what the exact scale of the problem is.
