08-21-2008 09:48 AM - edited 03-13-2019 05:35 PM
I have multicast paging enabled on the CM. But it does not seem to work for IP Communicator IP softphones.
pagin-dn is on for the soft phones... for example:
ephone 4
video
mac-address xxxx.xxxx.xxxx
paging-dn 52
type CIPC
button 1:4
I wanted to first confirm that IP Communicator will do multicast paging.
Software version 2.1.3.0
Thanks in advance.
Michel
08-22-2008 01:45 PM
CIPC will do multicast paging.... If fact that is how I enabled paging through overhead speakers and phones simultaneously.
In my experience, multicast paging issues are most commonly the result of having the affected device on a different VLAN from the rest of the phones and not having mulicast routing enabled.
08-25-2008 03:43 AM
Awesome, thank you. Back to troubleshooting I go.
08-25-2008 12:53 PM
Yes, IP Communicator does support multicast. I just tested sending and receiving a page via PhoneTop Messenger paging system and it worked.
08-26-2008 07:14 AM
Thank you for your responses.
I have resolved the issues as follows:
- I had changed the network size for voice demo from /26 to /27 and neglected to change the netmask on the voice router (teehee oops)
- I deleted and recreated the ephone setting for the CIPC type.
I believe that correcting the netmask on the voice router may resolve inconsistent behavior for all voice clients doing multicast paging. The CIPC phone still did not work, but deleting and recreating the phone in call manager fixed that.
