IP Communicator doesn't work with Cisco VPN Client
dsuntama
Im having problem to connect  IP Communicator (either ver 2 or 7 )whenever using Cisco VPN Client 5.0.06.0160 for windows
the IPC didn't register to the CUCM
There's nothing showing on the screen
but whenever im using  Anyconnect VPN Client, it works perfectly
The remote side is using ASA5505
Anyone can help ??
steigja
Level 3
Level 3
     It's probably an issue with the ASA configuration in your "group-policy attributes".  The "split-tunnel-network-list value" is pointing to an access list without the subnet for the call manager.  While your ssl group-policy for webvpn has a "split-tunnel network-list value" access-list which does contain the subnet for the call manager.
     The other issue could be that your using different ip pools for ipsec and ssl vpn.  The ip pool subnet that you might be giving out for ipsec might not be in your "no nat" acl.
Jason
Hi Jason,
Thanks for your reply.
I have checked that the group-policy for ipsec group and for webvpn has the same split tunnel network list and ip pool subnet
well i can reach the callmanager but however the IP Communicator can't register without any message to the Callmanager, I have set the TFTP Server and device name correctly on IPC
Any idea ?
David
