07-26-2004 11:57 AM - edited 03-13-2019 05:47 AM
CCM ver 3.3(3)
Client OS ver Windows XP Pro
I am having a problem with getting IP Communicator to update its time on a user's laptop. We are in the testing phase of the software rollout. Different Date/Time Group (than CMLocal) has been created and assigned to the Device Pool, after which the time updated fine on 2 other users' laptops.
Is anyone aware of any application (e.g.security-related) local to the client that could cause this problem?
Calls (and quality) to/from the Communicator go through very well.
Please help.
07-30-2004 11:18 AM
I haven't heard of such kind of problem. Check the software you are testing
08-04-2004 07:49 AM
I had a problem with the IP Communicator keeping the correct time. I am running CM 3.3(3). I found that you have to have the IP Communicator in a Date/Time Group. Not the default Date/Time Group.
Hope this helps
Trae
08-04-2004 12:31 PM
I have done this. It corrected the bug on 2 out of 3 machines. As it turns out it is a bigger problem than just the Date/Time Group issue. This Communicator is simply not synchronizing with CallManager.
We are still looking at it.
