IP phone acts as a switch or a hub?
juma
My PC is attached to the IP Phone and the IP phone is connected to a 4006 switch. My PC is on a separate VLAN as the IP phone. Started sniffer on my PC to capture sent and received traffic on my PC's NIC. Surprised to see that the sniffer trace contained voice traffic also. Do that mean the IP phone acts as a hub instead of a switch?
dumartin
That is correct. The IP phone is a hub.
5 Replies 5
dumartin
This reply is incorrect. The current IP phones have a 3 port *switch* (aka C3PO), with one port internal. They support 802.1q, have 4 queues (1P3Q1T), and prioritize CoS 5 traffic (voice) over data. CoS 5 traffic goes into the priority queue, all other traffic goes into queues 1-3. The queues are scheduled in round-robin fashion with a priority queue timer to make sure priority traffic gets out.
You are seeing traffic out both ports since one of the design goals was to be able to dual-home the phone for very high-availability designs. Check out CSCdr32892
Cannot locate CSCdr32892. Can you send me the URL or forward as an attachment?
Thanks..
dweiner
Sorry. This is not a bug, so is not posted. The pertinent text is:
"This works as designed. ...[Product design] specified that the
Telecaster MUST support "double homing" of its two links - allowing possible built-in "redundant" links for "very high availability" applications."
There needs to be a correction to my last reply. The phone acts as a switch not a hub. Sorry for the confusion.
