07-09-2007 01:47 AM - edited 03-15-2019 04:52 AM
Dear SIRS,
we use the IP-Softphone from Cisco for our internal VOIP-Communication between 2 offices. It works great.
But additionally we would use the MS-Communicator 2005 for application-sharing. When i try to get a application free, the MS-Communicator means, that one other applikation use this function at the same time. I think that's the IP-Soft-Phone, that use the same ports as the MS-Communicator 2005?
It is possible to use the 2 applications at the same time? IP-Soft-Phone for VOIP and Communicator for app-sharings?
Thanks for all answers in advance
BR
Roland
Solved! Go to Solution.
07-09-2007 06:23 AM
I don't think that any application will confict with IP communicator, as it uses 2000, not 2005.
07-09-2007 06:23 AM
07-10-2007 06:24 AM
Hi Mr. Bevilacqua ,
you're right. I found the failure why it doesn't work:
In the IP-Softphone-Options you can activate the collaboration for a virtual conference-room or collab with net-meeting. i had use the option with the virtual root and for testing with net-meeting, but you must disable all. And then you can work with booth applikations!
Thanks for help.
BR from Germany
Roland
