ip telephony and isdn modems
dzuodar
case: callmanager 3.3 in combination with a 1760 gateway containing 3 VWIC-2BRI-NT/TE cards for termination of the provider isdn lines
question: how can we make isdn modem calls from the inside network? which equipment should be used to connect these isdn modems to?
thanks for your help!
pacameron
Level 4
Level 4
Unfortuneately the VIC BRI Cards can only support
voice calls , they won't do modem or data calls. Aboutr the only way to do this is to use an external ISDN TA that will terminate the data calls and feed the traffic to the router via a serial port.
