Is it possible to combine gatekeeper and gateway functions?
tmoffett
Can a H.323 gateway also serve as a Gatekeeper on the 3600 platform?
pbarman
Level 5
Level 5
Yes, if you have the correct image. Look for 'x' in the image filename which gives gatekeeper functionality.
Example:-
c3660-ix-mz
Cisco 3660 Series IOS IP/H323 Image
pacameron
Level 4
Level 4
The IP/H323 feature set will only give a gatekeeper function. To have combined gateway/gatekeeper , you need the Enterprise Plus/H323 MCM feature set
