ISDN - PRI NI2
c.shepard
I have a Cisco Call Manager V3.2, Cisco 3640 Router, and a Definity G3. The definity has a TN464F. We are trying to set it up so that we use ISDN PRI NI2. They still will not communicate with each other. The Cisco is setup for the
isdn switch-type primary-ni
Controller T1 1/0
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
interface Serial1/0:23
no ip address
no logging event link-status
isdn incoming-voice voice
voice port 1/0:23
mgcp
mgcp call-agent 172.16.20.11 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp profile default
dial-peer voice 9991023 pots
destination-pattern .
no digit-strip
port 1/0:23
The definity is setup for
ds1 circuit pack....
isdn-pri signaling
protocol version b
connect: network
interface companding mulaw
trunk group.....
group type isdn
service type tie
supplemenary service protocol a
The call manager is setup with a gateway and the endpoint is setup mostly with defaults.
Is there something we are missing? When calling from ip phone we get a fast busy. When calling from a non ip we get a fast busy. If we use the Trunk access code we get a slow busy.
15 Replies 15
mramella
If you not able to get multiple frame established by doing a "sh isdn status" try placing "isdn bind-l3 ccm-manager" in the serial port for the trunk.
Example: (Sorry I had an an E1 config, should be no different)
controller E1 0/1
pri-group timeslots 1-31 service mgcp
interface Serial0/1:15
no ip address
isdn switch-type primary-net5
no cdp enable
