Issues initiating a conference using SW CFBs.
plafond12
Hi all
I'm having some issues initiating a conference using SW Conference bridges.
I'm using CUCM 8.6.2
I have 1 pub and 2 subs.
IPVMS is running on all 3 of them. All 3 of my SW CFBs  are registered (eventhough if i click on each of them, it says device is not trusted).
When i try to initiate a simple ad hoc conference with 3 users, when connecting the 3rd user, i get an immediate fast busy and the conference fails.
I tried restarting IPVMS with no luck.
Do you think the "device is not trusted" state might be an issue?
Jaime Valencia
As i told you in the other thread, start by checking codec/region/BW issues.
SW CFB is G711 only.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
Thanks, you nailed it again.
my codec was set for G729.
Cheers
