05-02-2012 03:37 AM - edited 03-13-2019 07:49 PM
As CUEAC data sheet, it can be running on ESXi 4.0/4.1, but any body knows if it can be running on vSphere 5 ?
Thanks so much.....
Solved! Go to Solution.
05-02-2012 03:43 AM
HI
Not supported yet, Please see below link to confirm what all application are supported in ESXi 5.
Ronak Patel
Please rate helpful posts by clicking stars below the answer.
05-02-2012 03:43 AM
HI
Ronak Patel
05-02-2012 03:51 AM
Hi Ronak:
Thanks so much...... But ESXi4.0/4.1 is EOL/EOS......
I think it is no way if we want perchase the CUEAC with VM......
Thanks and Regards
En-Zi
05-02-2012 03:57 AM
Let me see if we have some latest new on this.
Ronak Patel
05-02-2012 04:03 AM
Thanks Ronak !! :-)
Best Regards
En-Zi
05-02-2012 04:10 AM
Hi En-Zi,
Unfortunately the above link is correct. We still do not support ESXi 5.
This may come with Attendent consols 9.X release which may be released in summer time this year ( It is planned in CUAC 9.X release ). But we have to wait and see the actual support when it is released.
Ronak Patel
05-02-2012 12:35 PM
You can buy a vSphere 5 license and then downgrade it to vSphere 4 through the VMware licensing portal.
05-08-2012 09:00 AM
See here slated for 9
http://www.gossamer-threads.com/lists/cisco/voip/159013#159011
08-16-2012 05:43 AM
as per below link ESXi 5.0 is supported on CUEAC 8.6?? Also same link says BE6K not supported on ESXi 5 is that really true because Cisco has been shipping ESXi 5 with BE6K for ages now??
Aamir
08-16-2012 06:47 AM
08-16-2012 03:36 PM
Thanks Srini. it's a shame no one is updating docwiki which is causing so much confusion for everyone.
what about CUEAC though as per the link I posted earlier CUEAC 8.6 is supported on ESXi 5 right?
Aamir
08-16-2012 04:20 PM
I agree. Nope you have to be at 9, see the release notes. Also one more curve ball CUEAC 9 is not supported on BE6K because the minimum requirements for CUEAC 9 is not met by BE6K C220 or C200 box. Still to be fixed..
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmac/arc/CUACBE_Rel_N_9_0_1_10.pdf
Release Notes for Cisco Unified Business Attendant Console version 8.6.2
Srini
