12-02-2020 08:29 AM - edited 12-03-2020 01:56 AM
Hi guys,
I have the following problem in short explanation:
it is very simple to exlpain:
(from ITSP/LTE DTMF rtmap g711ALAW and lots of other in the SDP 101 /16000 and 111/8000) ----> CUBE------> (result only 111/8000 from cube) to CUCM.
So very short is see on side ITSP the SDP 8000 and 16000 and on the other side of the cube i don't see 16000
DTMF is working fine with 8000
Voice service voip or on the dial-peers in the cube:
i implement this ....................... voice-class sip asymmetric payload full with no result
Something is not so transparent as the cube says
Does anybody have a hint for me?
12-02-2020 08:30 AM - edited 12-03-2020 01:57 AM
12-16-2020 06:24 AM
Can you check that feature available in the CUBE devices also other device have the same feature
12-17-2020 04:48 AM
Check below every configuration
12-17-2020 04:56 AM
Protocol notify negotiation between devices duration
