08-18-2020 01:16 AM
We have a network with 2x3850 and 10x2960x.
We have above 200 cameras connected to the network.
While viewing about 25 cameras, the system is OK but over that,, it start to lag.
Do you have any idea how to solve same.
10-27-2020 04:48 PM
It will depend on your network topology and what the bandwidth of your links are between switches. If you're trying to feed too many large video streams down a small pipe, then you will obviously have issues.
Please remember to mark helpful responses and to set your question as answered if appropriate.
11-19-2020 08:14 PM
We had same issue with our Axis cameras. We found that the cameras working correctly were all on the same switch with the NVR. Cameras coming from other switches had high latency- we found out the IT department had set their trunk ports to 100Mbps and we were choking the pipe. They flipped the trunks to 1GB and issue was solved.
エキスパートの回答、ステップバイステップガイド、最新のトピックなどお気に入りのアイデアを見つけたら、あとで参照できるように保存しましょう。
コミュニティは初めてですか?これらのヒントを活用してスタートしましょう。 コミュニティの活用方法 新メンバーガイド
