Least Cost Routing of VOIP Calls
Dear Friends
Please suggest methods/resources to implement least cost routing of VOIP calls, such that the VOIP Gatekeeper interact with Billing Server, which has information of all rate plans,and decide the destination VOIP GW/E1 Ports to hand over the call to a specific Basic Service/Access Provider which provides the better rate at that moment.
Thanks & Regards
Shailendra
ciscomoderator
Community Manager
Community Manager
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you, or there is no public information available at this time. If you don't get a suitable response to your post, you may wish to review our resources at the online http://www.cisco.com/go/solutions. You may also contact our product information line at 1-800-553-NETS or a Cisco Systems Engineer at your local Cisco office or reseller. To locate your local Cisco representative, visit http://www.cisco.com/warp/public/687/Directory.shtml
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
jraarons
Usually it is cheaper to aggregate all your PSTN minutes to 1 carrier.
By the time you try and figure out all the least paths you can find a carrier for 2-6cents/minute. If you do it yourself you have more hardware spread out, higher costs of ownership, etc.
You have intra-lata and other issues. Their are companies that publish cd-roms of tarrif tables, etc. Your subscription cost more than the benefit.
From a international standpoint you have to worry about completion rates, etc. So Sprint may have a better rate, yet none of the calls will complete other than AT&T.
mobasshar
We have a product that in final beta at the moment. It run on a SUN Solaris platform, does SS7, H323 gateway, billing and LCR.
Its unfortunally geared for large carriers and not individual or Enterprise users.
If you have such a need e-mail me.
