LLQ Problems on Multilink
lwascher
I have a 7206 router that I am implementing QoS on. I create access lists, class-maps, and policy-maps to separate voice traffic and signaling. I have attached the policy map to a serial interface, and it is working great for VoIP. When I attach the policy map to a multilink interface, the router starts to bog down and eventually locks up. I have read every QoS, LLQ, Diffserv, and PQ documentation you have, and follow directions exactly. Any idea why this is not working? This is how I have it set up:
ip access-list extended ugw-traffic
permit udp any any eq 2427
permit udp any any eq 2727
permit udp any any range 3000 3590
permit udp any any range 16400 16990
class-map match-any voice-class
match access-group name ugw-traffic
policy-map LLQ
class voice-class
priority 400
class class-default
fair-queue
interface Multilink1
ip address xx.xx.xx.xx 255.255.255.252
ip ospf network point-to-point
ppp multilink
ppp multilink group 1
Service-policy output LLQ
interface Serial1/0/16:0
service-policy output LLQ
encapsulation ppp
pbarman
Level 5
Level 5
Looks like the serial interface config is posted incomplete here. Does the serial interface participate in multilink?
Apply service-policy to only the multilink interface and not on the participating physical interfaces, and see if that makes a difference. That's how it should be.
What is the IOS version on the router? If config is good, it may be a bug, search for bugs!
Post the config of the multilink and participating interfaces here, please.
This is pretty much what I have. I actually tried applying it to the multilink first, and only the multilink, and it worked fine for about 1 minute, then it started dropping packets until it dropped my connection. The cpu utilization shot way up during this period. I tried implementing it on just one of the serial interfaces by itself, and it works great. I've tried a few different combinations of things, all which do not work on the Multilink interfaces. I've checked the log after this happens, and nothing appears in log either. I have also set up the class-maps with to priorize DSCP packets, and this failed also. This is the IOS Version:IOS (tm) 7200 Software (C7200-JS-M), Version 12.3(1), RELEASE SOFTWARE (fc3)
policy-map LLQ
class voice-class
priority 400
class class-default
fair-queue
ppp multilink
encapsulation ppp
interface Serial1/0/1:0
no ip address
encapsulation ppp
ppp multilink
interface Serial1/0/2:0
no ip address
encapsulation ppp
ppp multilink
d.albertson
I don't know that this will solve all of your issues but you need to configure the serial port that is using multilink to use a fifo queue. By default the serial interface applies a fair-queue which over-rides the LLQ policy. If the link is slower than 768Kbps you should also apply MLP LFI.
no fair-queue
Dave
