I have a problem with long distance codes that are provided by the long distance provider. Basically we have a fax card that dials the phone number and inserts a couple ,'s for pauses and then dials the long distance code. The problem is that the card will not continue with the pauses unless it receives a connect message (answer supervision) back on the T1 CAS, so it always receives a busy signal because the code was never sent. Example 9705551212,,222
Does anyone know of a way to force the router to send a connect message as soon as the call is placed or build a dial-peer that will send the long distance code.
Any help would be greatly appreciated.
