10-14-2004 05:08 AM - edited 03-13-2019 06:40 AM
Folks,
I am not receiving caller id on the phones when users call from the PSTN. I see the digits come through on the gateways when i run "debug isdn q931".
I have MGCP configured between the CCM and the 3745 gateway. I have enabled all the options on the MGCP gateway to be on the safer side.But, still no luck, i get "UNKNOWN NUMBER" displayed on my phone when an PSTN user calls.
Do i have to enable something globally on CCM to turn on caller ID, any help would be highly appreciated.
10-20-2004 11:36 AM
I don't think you can configure CallerID when MGCP is used. You might need to change the MGCP gateway to H323 Gatway.
10-20-2004 11:50 AM
This statement is inaccurate.
MGCP is not currently supported with FXO interfaces, however this does not affect PRI which is what the orignial poster is using.
-jd
