Max Ad-Hoc parameter ? 6608 (one port)
mgvogt11
What do I set the Maximum Ad-Hoc Parameter too? I am under the impression that if I have one port on the 6608 setup for hardware conference I can have two session with 16 poeple on each conference call. If anyone can clear this up I would appreciate it.
We will be putting a redundant 6608 blade in soon with a second hardware conference port. Will I need to change the parameter again?
pbarman
Level 5
Level 5
That service parameter is global, so if you modify it that will affect your redundant 6608 also.
Set this value to whatever maximum number of participants you want in a single conference call. 6608 supports maximum 16 participants, so you may want to set it to 16 to use that functionality.
Also:
*For a G.711 or G.723 conference—32 conferencing participants per physical port; maximum conference size of 16 participants
*For a G.729 conference—24 conferencing participants per physical port; maximum conference size of 16 participants
So, you can have more than 2 conf sessions, provided the total number of participants donot exceed the stats above, for any given port and codec.
