to reduce the dial peer statments or configuration in the VOIP, MCM will help.
I have diffculty in managing the dial peers .. i have sixty 1750v routers enabled with VOIP. In HO i have 3640.
i understand with MCM .. 1750 can first register with MCM to get the ip number to dial .. and i have to configure only the pots in the 1750 .
if mcm will help.. then where i should deploy the MCM.. in HO? then if in case of wan congestion , do 1750 will have diffculty in registering with MCM? any QOS required for h323 traffic.. currently i use RSVP with wfq.
which ios will support this mcm on 3640..
